Re: Hub interchange???
Posted by RPM1941 on February 12, 2011 at 08:06:25 from (173.25.71.175):
In Reply to: Re: Hub interchange??? posted by RPM1941 on February 11, 2011 at 16:28:39:
The pedestal bolt pattern is the same on H thru 350, M is bigger, same as 4/560/656/66/86/7/806& up thru 1586 with tri axle option, spindles are easy to id by size of nut for hub, coarse thread is 3/4 for H/350, 7/8 NC for M/450, fine 3/4 is for 460/656, all 7/8 NF is for 666/686/706 & up, there is only 2 bolt pattern also, 6 bolt & 8 bolt on newer disc wheels, H/450 had cast hub & wheel with 3 lug. There is few exceptions but being in parts at IH/CNH for 47 years not enough room for all info on this forum.
