Re: Stuck on Steering
Posted by Lee Jr. on February 12, 2011 at 09:16:10 from (209.145.128.34):
In Reply to: Re: Stuck on Steering posted by Lee Jr. on February 11, 2011 at 19:59:40:
What a mess. I finally got the worm gear/shaft out (thanks for the advice) only to find someone welded the the worm gear shaft to the steering knuckle. I assume they lost the key that holds it on place and merely welded it. So, I took my cut off wheel and cut the shaft, removed it from the main front steering gear, then removed the U-Joint and carefully cut around the weld to save the steering knuckle. So I guess I'll get a new U-Joint, mount the power steering and see how it goes back together. While it is apart I believe I will rebuild the carb, have the radiator looked at it appears to be leaking and possibly install and new intake/exhaust gasket. Thanks for the advice on the steering. Appreciate this forum.
