Posted by CNKS on February 12, 2011 at 09:25:11 from (216.144.104.128):
In Reply to: Re: No oil pressure. posted by El Toro on February 12, 2011 at 08:31:09:
OK, now I have to decide if I want to remove everything in the way of the front cover and see if I put that plug in there. Block # is same as mine. I cannot believe I would have left that plug out -- that would be a large, fully visible hole behind the gear, and I am looking right at it as I install the cam. Stranger things have happened, I suppose. But if true, this one will be a new record. Thanks for the info, if I decide to look as a last resort, it will be a few days. I have no problem disassembling everything once, but I hate twice.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
