I would look for a ballast resistor between the ignition switch and your coil that's probably defective. To make sure its not the switch use a volt meter and check the run terminal on the switch for voltage when the switch is in the run position. If there's voltage on the terminal I think your switch is ok. Boats with inboard engines also used this setup with a ballast resistor. Hal
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
