I think you will find that the resistor is built into the wiring harness on that model. The resistor is actually the wire that comes from a connector near the ignition switch and goes to the starter solenoid. the wire itself under the insulation will be a silver/gray color rather than plain copper.
The way to tell for sure is to look at where the wires connect to the ignition coil and at the I terminal on the solenoid. If the coil has two wires attached on the battery side and the solenoid has only one there will an external resistor somewhere near the coil. If the coil has only one wire attached coming from the ignition switch and the solenoid has two on the I terminal you have the resistance built into the wiring harness.
If you find the wire is broken you can try repairing it or just replace that section of wire with copper and adding an external resistor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
