Re: Battery Voltage on 966?
Posted by El Toro on February 13, 2011 at 06:56:53 from (108.3.200.96):
In Reply to: Battery Voltage on 966? posted by kellyc on February 13, 2011 at 06:20:34:
You need to see how many cells each battery has.
You probably have 2 six volt batteries hookup in series to give you 12 volts to the starter. You should be able to charge both batteries by connecting your positive battery cable on the plus + terminal that goes to your starter. Then connect the negative cable on your battery charger to battery terminal that's grounded on the other battery. Hal
PS A pic would help.
grd- + - += 12 volts
