Re: M Serial numbers
Posted by CNKS on February 13, 2011 at 08:24:27 from (216.144.104.128):
In Reply to: M Serial numbers posted by Ally Cat on February 13, 2011 at 08:08:33:
1st answer, No, each engine has separate part numbers. Part numbers, not suffixes are used in ordering. 2nd answer, Gasoline engine as opposed to kerosene or distillate. 3rd answer, no.
