Farmall Tractors Discussion Board
Re: Farmall A crank pulley
Posted by Jim Smith Ft wayne on January 03, 1999 at 12:53:37:
In Reply to: Farmall A crank pulley posted by Brian on January 03, 1999 at 09:00:36:
Its a press fit, you need a good puller and a bearing splitter. TO get it back on heat it up,
work fast. You may be able to use a bolt in the
end of the crank to push it back on. Put the bearing puller behing the pulley and hook the puller on to it, a lot of people still break them though. Good luck
jim
Post a Followup
: Re: Re: Farmall A crank pulley
