Re: Just about had enough of this SUPER C!!
Posted by 400Dtractorman on February 13, 2011 at 16:39:41 from (24.112.136.165):
In Reply to: Just about had enough of this SUPER C!! posted by John826diesel on February 13, 2011 at 15:41:22:
I have a 400D with the similar problem.
Mine is the bearing on the main shaft. The faster it goes the louder it sounds. Mine has some grinding also. You probable don't hear it in first gear. Get a SC shop manual and it should have a bearing on the main shaft somewhere. I'm not sure if you can check it out without taking it back apart. Hope this helps.
