Re: Just about had enough of this SUPER C!!
Posted by CNKS on February 13, 2011 at 16:47:06 from (216.144.104.128):
In Reply to: Just about had enough of this SUPER C!! posted by John826diesel on February 13, 2011 at 15:41:22:
Well, you now have a good transmission. Did the same to my Super A, but I have not driven it yet. The noise could also be caused by a loose clamp on the axle or loose rim bolts, they may seem tight, but really aren't. I assume you have already been told all this. It could be an axle bearing. There is an inner and an outer. Remove one rear wheel and try to move the axle. There is not supposed to be any play, or with normal wear, maybe minimal. You might also try pushing the tractor with engine off. SC is not too hard to move if you have concrete.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
