Re: Just about had enough of this SUPER C!!
Posted by okierob on February 13, 2011 at 17:00:56 from (65.67.203.82):
In Reply to: Just about had enough of this SUPER C!! posted by John826diesel on February 13, 2011 at 15:41:22:
the mainshaft and countershaft splines could be worn also. just because the gear teeth looked good the splines could be loose.
