Re: h- front end
Posted by David G on February 13, 2011 at 17:09:34 from (75.221.157.24):
In Reply to: h- front end posted by ron robinson on February 13, 2011 at 04:22:04:
Mine had a bad lower bearing, along with worn worm gears. The lower bearing was the worst of the problem, so replacing that made it much better.
