Re: No oil pressure.
Posted by Roger46 on February 13, 2011 at 18:04:47 from (72.100.34.238):
In Reply to: Re: No oil pressure. posted by CNKS on February 13, 2011 at 08:43:23:
Somebody asked a similar question several months ago. I was working on my A at the time and I suggested he take off the oil gallery plug under the distributor and run a wire forward to see if that front plug is there. I think that is what he did to verify that the plug was or was not in place. Something to try before pulling the front cover. Roger
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
