Re: SA oil pressure solved.
Posted by Owen Aaland on February 14, 2011 at 00:53:24 from (65.174.247.20):
In Reply to: SA oil pressure solved. posted by CNKS on February 13, 2011 at 16:35:16:
You need to thank Wardner for the air pressure idea. I only added that you might be able to see or hear it if you removed the governor.
