Posted by mkirsch on February 14, 2011 at 05:08:59 from (64.80.108.57):
In Reply to: w9 posted by Rick in Iowa on February 12, 2011 at 18:25:37:
Hopefully you're not pulling on the rim of the pulley with one of those jaw-type pullers... If you put much more pressure on it you'll shatter the pulley.
Use a bearing separator at the very least so you're pulling against
WD-40= waste of time and perfectly good alcohol
Propane torch = waste of time and perfectly good propane
I've seen some pretty heavy-duty rigs used to pull those front pulleys, using some thick pieces of flat plate, 3/4" all-thread, and a 20-ton bottle jack!
You need to get brave with a REAL torch, oxy-acetylene. Heat the pulley while putting pressure on it with the puller and bearing separator. Don't be afraid to get it red-hot. You'll need a new front seal, but odds are you were going to replace that anyway.
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It
... [Read Article]
Latest Ad:
[More Ads]
