Tranny Oil Capacity in an H
Posted by IHRedRules on February 14, 2011 at 05:22:02 from (199.150.151.20):
Finally had a nice thaw, so now my H is no longer frozen in place from water in the tranny. Anyone know what the capacity is for oil in the tranny? Are you guys using Hy-Tran or 80/90? Last question, what sort of tool are you using to remove the filler plug, I know on a Super A I could use my breaker bar, but I certainly don't have any breaker bar big enough for the H?
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
