Posted by Janicholson on February 14, 2011 at 06:24:41 from (199.17.6.194):
In Reply to: M Block repair posted by FarmerBrawn on February 14, 2011 at 06:03:29:
A cut is easy to repair. If it is easily accessed and not too deep, a braze job on it would be pretty easy and certain fix. If it is a crack, then it will be more difficult.
The sleeve ring at the top of the cylinder bore is usually wide enough to prevent water leaks across the gasket into the cylinder. If the sleeve is cracked, just replace it. Fixing a sleeve is like taking a 20 dolar watch in for circuit repair. A cut in the casting of the block into a water passage is not good, but if not drastic, will not prevent the reliable operation of the engine. If the crack is drastic when the sleeve is pulled, the cylinder can still be saved with a repair (thick) sleeve installed into a bored out block, then re-machined for the liner sleeve ring. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
