Timing marks on the crankshaft pulley and the pointer on the front cover.
#1 Cyl is the first by the radiator.
As long as you did not remove the pump drive shaft from the engine you do not need to have the engine set to any particular cylinder. The pump can only be installed two ways. Just match the dimple on the end of the shaft to the dimple in the pump and you will be on the correct cylinder.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
