Re: SA oil pressure solved.
Posted by El Toro on February 14, 2011 at 09:12:11 from (108.3.200.96):
In Reply to: SA oil pressure solved. posted by CNKS on February 13, 2011 at 16:35:16:
You probably would've remembered those plugs had you removed them. If you have a pressure vessel that you can force engine oil into the oil gallery I would use it. That would force engine oil to all the bearings and rocker arms. Hal
