Kelly, Good to see you back, on the boards. A 966 is a great tractor for I have one also. The Batts are connected in series like this ,,,,, 2,,, 6 volt batts, in this fashion ......., Starter,to->HL Batt--> + --> - to RH Batt--> + --> - ..to Ground (frame). Pretty much like El Toro said. The DT414 doesn't like to idle around they will go to slobbering oil out the exhaust., if it that happens just hook it to a heavy plow and run her hard for a couple of hrs it will stop. Being you do not have a loader on it that may not be a big problem. Hope this helps, Take Care, Hope this helps Later, John A.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
