Re: 966 battery question again.
Posted by Janicholson on February 15, 2011 at 10:14:12 from (199.17.6.194):
In Reply to: 966 battery question again. posted by Kellyc on February 15, 2011 at 10:01:23:
Batterys as described are from ground to 6volt battery (1) negative terminal from battery 1 positive terminal to Battery 2 negative terminal, From battery 2 positive to starter system heavy wires. This is 12 volt total with a negative ground. It can be charged in two ways, either will work.
A 6volt charger can be placed on Battery 1 with Pos to Pos, Neg to Neg. Then when it is charged tha charger can be placed on Battery 2 Pos to Pos, Neg to Neg. When both are charged it is good to go.
The other way is to hook a 12 volt charger to Battery 2 Negative, and Battery 1 Positive.
This will charge both at the same time.
Specific gravity testing would be a good check on cell condition. and state of charge. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
