Re: Farmall clutch
Posted by rustred on February 15, 2011 at 14:28:39 from (74.200.18.155):
In Reply to: Farmall clutch posted by MtMan on February 15, 2011 at 11:45:22:
another thing is: as the disc is wearing the freeplay keeps decreasing and must be adjusted periodically . once the disc is worn out a lot of times you cant "get" freeplay. your last sentence makes no sense, as freeplay is the space from the brg to the adjustment bolts. like yes most pedal free travel is 3/4 to 1" but you can feel when the brg contacts the fingers. was the flywheel resurfaced? and if it is a stepped flywheel need to remove the same amount of meat from both surfaces.
