Re: I messed with the distributor timing on my M
Posted by CNKS on February 15, 2011 at 17:42:47 from (216.144.104.128):
In Reply to: I messed with the distributor timing on my M posted by NolanJae on February 15, 2011 at 17:26:14:
The front section only goes in one way. If you did not turn the engine over when it was out it shouldn't matter. Set the engine at TDC, timing marks should align. Remove the distributer, not the distributer drive. Point the rotor to #1 on the distributer cap. Install the distributer without rotating the distributer gear. When installed, rotate the distributer counter clockwise viewed from the rear. Turn the ignition on, remove the coil wire from the distributer cap, hold the end close to the nut on the distributer and slowly rotate the distributer clockwise until you get a spark. It should be timed. You can further time it with a light. Maybe a little more precise if you know the # degrees to advance but not much.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
