Re: siezed 300 IH
Posted by 504 on February 15, 2011 at 17:49:40 from (64.111.61.44):
In Reply to: siezed 300 IH posted by p. guy on February 15, 2011 at 17:00:05:
Jack the front wheels up with the pole and put a 4X4 across the block and hit with a BFH, at least a ten # sledge hammer. When I did this with my SC it put a steel rod through the piston, but the liner came out too.
