Re: I messed with the distributor timing on my M
Posted by CNKS on February 15, 2011 at 18:48:58 from (216.144.104.128):
In Reply to: Re: I messed with the distributor timing on my M posted by NolanJae on February 15, 2011 at 18:05:52:
You must be using the Operators Manual. When I looked at the picture I remembered the 35 degree from horizontal thing for the lugs Been a while since I did that, but I don't remember any particular problem. What I was referring to is on page 42, a little more detailed than my explanation. You are correct that the distributer can go in any position. To point to #1, install the distributer cap and use a felt pen to line a mark on the body up with #1 on the cap. As I said, then install the distributer into the drive without rotating the dist gear. Book says if the ammeter does not show a discharge you do not need to rotate the dist counter clockwise. The rest is in the book.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
