I installed a Pertronix on a Ferguson 35 and it worked fine until.... After a heavy snowfall, I started the tractor to let it warm before moving some snow. I let it run while I did some other chores. After one half hour or so I noticed the tractor was no longer running. I thought maybe iceing as it was single digit temps so checked everything and saw nothing wrong. Tried to restart and no-go. Too cold to further trouble shoot. After the weather moderated, I pulled the distributor cap and noticed a burned plastic odor. Inspection showed a pile of melted plastic in place of the module. Changed back to original points and condensor. Still no fire. Changed coil and started right up. Bottom line, I have no idea what caused the meltdown.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
