its the old style logo, has the i-h inside a circle. is your saginaw set up for two way operation? if you have two way cylinders, you can do a little plumbing from the belly pump with a spool valve and get two way hydraulics. here is a pic of the char-lynn spool valve mounted under the gas tank. it has a control rod that runs up next to the belly pump control rod. what i did is weld a short nub off a 5/16 bolt to the belly control rod for a second stop to hold the pump full on and control with the spool valve. its not factory i-h and wont pass the correct police, but i really dont care. this is a working tractor, not a trailer queen!!
it also has a 12v generator conversion, key with push button starter off a solenoid.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
