Posted by Janicholson on February 16, 2011 at 16:17:59 from (67.72.98.45):
In Reply to: tranny trouble posted by harvey ih on February 16, 2011 at 15:29:21:
The gear motion is not normal. There could be a bad bearing or bearing retainer on that front shaft. The jumping out is a combination of slightly worn shifter forks, rounded off splines on the input shaft, and mating splines on the 4th-5th slider, and possible weak springs.rust damage on the detent ball in the rails. New replacement gear and front shaft can be had (or good used). The reason they eventually go out is the grinding into fifth from forth when on the road (remember it is more than 50 yrs old!) Best of luck, there are many posts with pictures for the gears and solutions. An H is the exact same layout (not interchangeable, but the pictures can interchange. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
