Remove front hyd pump
Posted by Larry B 1486 on February 17, 2011 at 04:48:43 from (67.142.161.31):
I guess I need to replace the front pump in my 1466. Last summer the steering was getting slow to turn and thought the steering motor was getting bad. I started the tractor yesterday, not been started sence first part of last Nov, and I did not have any steering, brakes or hyd clutch. The 3pt works and have 2000 psi on the rear remotes. I have never removed the front pump so do I take all the bolts out around the cover or are there some bolts in the middle that needs to come out? There is no TA in this tractor. Could it be something else beside the front pump. Has new filter and little over full on oil. Anyone tell me how to remove the pump and replace it. Any O-rings or springs I need to look for?
