Re: Farmall H help needed
Posted by Janicholson on February 17, 2011 at 06:41:20 from (199.17.6.194):
In Reply to: Re: Farmall H help needed posted by Steven Thompson on February 17, 2011 at 06:33:37:
With that added info, I would say the throttle shaft, and governor are gummy from sitting. I would tollerate it for a month or so to see if it gets better. If not I would pull the side plate off of the governor and clean and oil the components. Don't get cleaner of scrapings into the engine. The throttle shaft is only accessable by carb removal. Be careful with the tang and slot as described above. Jim
