F20 overdrive
Posted by bigr on February 17, 2011 at 13:16:26 from (199.30.168.102):
I'm looking at an F20 parts tractor that has an overdrive on it. It looks like an aluminum box about 8" wide x 12" tall with a lever coming out the right side (pulley side). It's bolted to the front of the tranny. There is a bracket on the transmission, when the OD is engaged the OD lever comes up an locks into the bracket to hold it engaged. I don't see any brand or numbers on it. Does anyone have any info on it? It engages, but is there way to make sure it works before I put it on my '39? Any other info would be great! Thanks!
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
