Re: injector pump oil level
Posted by Brad Motheral on February 17, 2011 at 16:03:58 from (208.114.178.24):
In Reply to: injector pump oil level posted by 400D on February 17, 2011 at 15:49:58:
primary pump seal is probably leaking. shutting the fuel off after shutdown helps. running it with diesel in it WILL eventually wreck it. if it's a B pump you can still get the seal from CIH. if it's an A or pre-A pump it's sealed with a packing gland so you'll have to buy some packing rope and reseal it that way.
