Re: injector pump oil level
Posted by rustred on February 17, 2011 at 16:15:47 from (74.200.18.155):
In Reply to: injector pump oil level posted by 400D on February 17, 2011 at 15:49:58:
pretty well most of the ones i have seen are that way. i just drain out the diesel and fill them up with engine oil. drain them down as required and change the oil again when it appears thinned by the diesel.it would need the front seals replaced in the primary pump to fix the leak.
