Hard Starting M-------3
Posted by Tedd on February 18, 2011 at 05:40:23 from (4.26.41.58):
I have my M running, finally. Thank you for the help. It was the coil. I was all-set to remove the pertronics ignition unit and try points but I tried the simple check of the coil first and it started up. Of all the times in the past when I swapped a coil to check a problem it never was the coil.
Thanks to Hal and others that posted.
