Re: farmall h 6 volt cutout switch
Posted by pete 23 on February 18, 2011 at 10:02:26 from (173.87.146.142):
In Reply to: farmall h 6 volt cutout switch posted by Marlin taylor on February 18, 2011 at 09:12:22:
You can hook it up like Rusty says or you can just use the cut out portion of the regulator and use high and low charge like the original H used with a cutout if you want. If you could get just the cut out similar to the original it will cost as much as the regulator anyway.
