Re: Farmall M trans input seal.... help
Posted by kevinj54 on February 18, 2011 at 11:22:18 from (99.39.189.166):
In Reply to: Farmall M trans input seal.... help posted by mikeintn on February 18, 2011 at 07:46:34:
Remove the clutch cover bolts and drop the assembly down.
