Re: H carb gas leak
Posted by glennster on February 18, 2011 at 17:05:14 from (99.90.9.153):
In Reply to: H carb gas leak posted by Zachary Hoyt on February 18, 2011 at 15:45:08:
also check real close around the square head plug. my h has a hair line crack where the plug was over tightened at some point in the past, and somebody tried to braze it.
