Re: Voltage to RPM Converter
Posted by Janicholson on February 18, 2011 at 18:10:44 from (67.72.98.45):
In Reply to: Voltage to RPM Converter posted by WSJ on February 17, 2011 at 17:24:12:
If you are into electronics, I see the controller sensor AD converters for the readout placed in a "black box" under the hood where the starting tank would normally be located. A tiny push button on the bottom of the existing meter panel would send a signal to the "box" indexing a solenoid operated rotary switch, or more logic, to change functions.
All very discrete. Jim
