Re: 560 sleeve explosion-million dollar question
Posted by pete 23 on February 18, 2011 at 18:31:08 from (173.87.146.142):
In Reply to: 560 sleeve explosion-million dollar question posted by NolanJae on February 18, 2011 at 18:19:27:
By all means you can get away with repairing just one cyl. Trick will be to get a nice snug fitting sleeve in a well cleaned bore. I would put in a .002 oversize myself but that requires some honeing of block with a "rigid" hone, not a glaze buster type with spring loaded stones. You most likely won't find any sizing numbers on that engine block and if you could would not be able to find sleeves to correspond. Also, watch the counter bore and sleeve flange protrusion over block. Must be with in .002 of ajoining cylinders.
