Posted by Janicholson on February 18, 2011 at 19:09:57 from (67.72.98.45):
In Reply to: 140 farmall clutch posted by clearwater on February 18, 2011 at 18:42:41:
With respect, the transmission is straight cut spur gears which slide into one another along a shaft. There is no mechanism to allow this trans to be shifted between gears on the "fly". If you are starting from neutral, and push in the clutch, wait 10 to 15 seconds, then put it in the gear you intend to use. If you want to change gears, stop, leave the clutch in, and change gears. If this make it stop grinding, it is the way they are. If it grinds when ever it is shifted at full stop, or will not allow clash free shifting from a stop with the clutch down all the way and time allows the gears to stop, then the clutch, or pilot bearing might be at fault. Jim
Today's Featured Article - The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend.
... [Read Article]
Latest Ad:
[More Ads]
