Posted by Zachary Hoyt on February 18, 2011 at 19:22:55 from (173.86.125.69):
In Reply to: Re: H carb gas leak posted by Janicholson on February 18, 2011 at 19:16:11:
Thank you very much for your advice. I had thought it couldn't be the needle and seat or the float because it leaked in just the same way when I had shut off the gas at the sediment bowl and let the tractor run till it stalled, but could it be that there is still enough gas to be coming in and overflowing it but not enough for it to run on? I don't know much of anything about how they work internally. Thanks again. Zach
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
