Re: 706/560 injectors
Posted by rustred on February 19, 2011 at 07:06:28 from (74.200.18.155):
In Reply to: 706/560 injectors posted by JWCarp on February 19, 2011 at 06:27:43:
the 560 has an early type and later type injectors.early type has higher pressures and later type has lower pressures. i believe if you use the later type then they should workin the 706.
early- opening pres.1525-1625 minimum 1350psi
late - " " 950-1050 minimum 850psi
might be best to have them bench tested first.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
