Posted by ScottyHOMEy on February 19, 2011 at 08:50:21 from (71.241.215.34):
In Reply to: Super A rebuild posted by CNKS on February 18, 2011 at 18:48:18:
If the top of your clutch fork is hinged like it was on the As and Bs, it should be on just a tapered pin that drives straight through the torque tube. Check to see that that pin is centered,, i.e., the pin is recessed to about the same depth on each end. There's a certain amount of float where the fork, carrier and bearing can slide side-to-side so it can float on the shaft and in contact with the cingers, but it's limited by the gap betweeen the shaft and the bearing center. If the pin is holding it too far off to one side, your bearing will be off center, and won't center itself on the fingers. It will operate the clutch, but if the bearing is off-center, and it's under tension you could be a chafing the shaft against the center of the bearing, and the bearing will be spinning around a different center than the rest of the driveline.
BTDT. Could be as simple as that, and worth checking/trying before you decide to tear into it again.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
