Re: SM Clutch
Posted by Janicholson on February 19, 2011 at 15:53:18 from (67.72.98.45):
In Reply to: Re: SM Clutch posted by Budd Kaiser on February 19, 2011 at 14:29:46:
With the new information, I believe the issue is in the rod linkage going on the outside of the tractor.
They do not have internal parts that get wrong for no reason. The caseih.com sight has diagrams to see the components. Put in Farmall in the descriptor box when you get there.
The pedal is adjusted so that there is one and one eighth inch of free travel between the foot plate of the tractor and the pedal stop on the pedal when the pedal is pushed in by hand. The pedal is pushed only until clutch resistance id felt, not running. If this is set correctly by adjusting the long rod it should be fine. Jim
