Re: Farmall M trans input seal.... help
Posted by kevinj54 on February 19, 2011 at 16:45:48 from (71.115.142.178):
In Reply to: Farmall M trans input seal.... help posted by Ron W on February 18, 2011 at 07:46:34:
Stemmy said: (quoted from post at 20:18:39 02/19/11) well as my luck would have it Im going to end up splitting the tractor so I can get the input coupling off, so much for a quick seal replacement job.
Are you having problems dropping the clutch????. You MUST drop the clutch, sleeve, clutch cover, and input shaft as one piece.
Oh, and you may need to pull the release bearing shaft out to get clearance if you have the clutch cover that can't be caged down. ( I have that one )
I done mine last fall, it is tight but it will all come apart just fine.
This post was edited by kevinj54 at 16:48:24 02/19/11.
