Re: Farmall M trans input seal.... help
Posted by sflem849 on February 19, 2011 at 17:06:28 from (69.197.84.192):
In Reply to: Farmall M trans input seal.... help posted by wallacedw on February 18, 2011 at 07:46:34:
What do you mean when you say clutch? Like the PP and friction disc? Just wondering.
To the OP, don't forget to screw the three bolts in the tapped holes to take the pressure off. That will help you get the clutch in and out.
