Re: IH 300 Utility Loader - No Front PTO
Posted by Wardner on February 19, 2011 at 18:35:19 from (209.86.226.34):
In Reply to: Re: IH 300 Utility Loader - No Front PTO posted by Janicholson on February 19, 2011 at 16:33:39:
third party image
This is easier. The keyed shaft and coupling are available from the Surplus Center in NE. The only machine work is the 1/2" hole through the coupling. What's not shown is the solid coupling at the front end of shaft. Match the shaft diameter size and one half of the flexible coupling to pump shaft, probably one inch. In fact, everything will probably be one inch except the front end of crankshaft which will be 1.375" (I think). Everything can be done without any tractor disassembly except driving out the crankshaft rollpin.
