You can use road gear all you want using good judgement as to how rough the road is your running on and the weight of the load you're trying to pull....don't make a habit of overloading the engine or "grinding the gears" shifting into road gear from 4th on the go. Farmall H's and M's will start slipping out of 5th if you grind the gears shifting them into 5th on the go too much because it is a dog clutch you are engaging and if the teeth get rounded off on the companion clutch members the detent on the shift rail cannot hold the dog clutching gears in engagement. Also if you bounce an H or M family tractor around too much on rough ground (especially in road gear) it will eventually break the capscrews (bolts) holding the clutch housing to the transmission housing. These capscrews are inside the housing and you might not notice any of them broken until it's too late.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
