Posted by CNKS on February 19, 2011 at 19:20:09 from (216.144.104.128):
In Reply to: Re: SM Clutch posted by CNKS on February 19, 2011 at 18:06:40:
Reread your post, you said the shaft (rear shaft) the pedals are on, not the front shaft. Clutch pedal has a rod that goes to the front shaft we mentioned that holds the clutch release bearing, etc. The rear shaft does nothing except serve as a shaft for the pedals only. Replacing it alone has no effect on the operation of the clutch. Don't mess with the fingers, unless they are out of line with each other, each one has to be the same distance from the release bearing. Moving them in or out adjusts the pedal clearance, adjusting the pedals changes the clearance between the fingers and the release bearing. Easiest to adjust the rod going to the pedal. You must have done something else.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
