Re: 300U Knuckle/Front Arm adjust
Posted by Janicholson on February 20, 2011 at 08:04:39 from (67.72.98.45):
In Reply to: Re: 300U Knuckle/Front Arm adjust posted by Dellbertt on February 20, 2011 at 05:49:34:
If the box is out of synchronization internally the right arm will be off of its correct position, thus the toe in. The facts are also indicating the same issue. I asked the full travel diagnostic to assess that fact. The fact that the right arm gets no slop at all full travel one way suggests it is out of position, and being pushed against the case inside (it should not) it should act just like the left arm at its extremes. There is only tearing into the box and looking for a replacement. THe best of the boxes is a power system off of a 350U, or with slight mounting changes the box off of a 460U is way much better than either 300 or 350 components. Jim
